Změna barvy
Vaclav
Datum: 2.3. 2010 | Zobrazeno: 19312x
Poskládal jsem makro na generování kusovníku z různých fór. Výsledek snažení je v příloze.
To co jsem zatím nebyl schopen dodělat ani nikde najít je jak obarvit a změnit tlouštku ohraničení tabulky. Prosím pokud někdo ví ať napoví. Díky
makro:
Private Sub CommandButton1_Click()
On Error Resume Next
'Declare Variables
Dim oDocument As Document
Dim oDrawingDoc As DrawingDocument
Dim oDrawingSheets As DrawingSheets
Dim oDrawingSheet As DrawingSheet
Dim oDrawingViews As DrawingViews
Dim oDrawingView As DrawingView
Dim oDrawingTables As DrawingTables
Dim oDrawingTable As DrawingTable
Dim oBackgroundView As DrawingView
Dim oProductDoc As ProductDocument
Dim oProducts As Products
Dim oProduct As Product
Dim TempProduct As Product
Dim QtyDict As Variant
Dim Width As Integer
Dim height As Integer
Dim xOffSet As Integer
Dim yOffSet As Integer
Dim XOrig As Integer
Dim YOrig As Integer
'Check that the ActiveDocument is a CATDrawing.
'If not, inform the user and terminate execution.
Set oDocument = CATIA.ActiveDocument
If Right(oDocument.FullName, 10) <> "CATDrawing" Then
MsgBox "This utility must be executed from a within a CATDrawing."
Exit Sub
End If
'Populate the Variables
'On Error GoTo SubError
Set oDrawingDoc = CATIA.ActiveDocument
Set oDrawingSheets = oDrawingDoc.Sheets
Set oDrawingSheet = oDrawingSheets.ActiveSheet
Set oDrawingViews = oDrawingSheet.Views
Set oDrawingView = oDrawingViews.Item(3)
Set oBackgroundView = oDrawingViews.Item("Background View")
Set oDrawingTables = oBackgroundView.Tables
Err.Clear
'Check that the linked document is a product and not a part
Set oProductDoc = oDrawingView.GenerativeLinks.FirstLink.Parent
If Err.Number <> 0 Then
MsgBox "The linked model is not a product!", vbExclamation
Exit Sub
End If
Set oProducts = oProductDoc.Product.Products
Set QtyDict = CreateObject("Scripting.Dictionary")
'get the sheet dimensions so that we can place the bom in the right
'place relative to the drawing border
xOffSet = -12.7
yOffSet = 319.7
Width = oDrawingSheet.GetPaperWidth
height = oDrawingSheet.GetPaperHeight
XOrig = Width + xOffset
YOrig = yOffset
'Scan through the Product Structure of the assembly noteing the quantity of
'Each component. Add one of Each component to a list of the products for
'future use.
Dim n As Integer
Dim SourceText As String
Dim ProductList(50) As Product
Dim Index As Integer
Index = 1
For n = 1 To oProducts.Count
Set TempProduct = oProducts.Item(n)
If QtyDict.exists(TempProduct.PartNumber) = True Then
QtyDict.Item(TempProduct.PartNumber) = QtyDict.Item(TempProduct.PartNumber) + 1
Else
QtyDict.Add TempProduct.PartNumber, 1
Set ProductList(Index) = TempProduct
Index = Index + 1
End If
Next n
'Check to see If a BOM hAs already been created on the Drawing.
'This code will be utilized when updates to the BOM are needed.
'If the BOM table already exists, skip to the code which will
'populate the BOM.
For n = 1 To oDrawingTables.Count
Set oDrawingTable = oDrawingTables.Item(n)
If oDrawingTable.Name = "DrawingBOM" Then
GoTo POPULATEBOM
End If
Next n
'If the table does not exist, create one and label it the same as
'the table name being searched for.
Set oDrawingTable = oDrawingTables.Add(XOrig, YOrig, QtyDict.Count + 1, 5, 3, 5)
oDrawingTable.AnchorPoint = CatTableBottomRight
'Populate the cells of the BOM Table
POPULATEBOM:
Call oDrawingTable.SetCellString(oDrawingTable.NumberOfRows, 1, "ITEM")
Call Dressup_Table_bot(oDrawingTable, oDrawingTable.NumberOfRows, 1, 1, 0)
Call oDrawingTable.SetCellString(oDrawingTable.NumberOfRows, 2, "REQ")
Call Dressup_Table_bot(oDrawingTable, oDrawingTable.NumberOfRows, 2, 1, 0)
Call oDrawingTable.SetCellString(oDrawingTable.NumberOfRows, 3, "REV")
Call Dressup_Table_bot(oDrawingTable, oDrawingTable.NumberOfRows, 3, 1, 0)
Call oDrawingTable.SetCellString(oDrawingTable.NumberOfRows, 4, "PART NUMBER")
Call Dressup_Table_bot(oDrawingTable, oDrawingTable.NumberOfRows, 4, 1, 0)
Call oDrawingTable.SetCellString(oDrawingTable.NumberOfRows, 5, "DESCRIPTION")
Call Dressup_Table_bot(oDrawingTable, oDrawingTable.NumberOfRows, 5, 1, 0)
Call oDrawingTable.SetColumnSize(1, 12)
Call oDrawingTable.SetColumnSize(2, 10)
Call oDrawingTable.SetColumnSize(3, 10)
Call oDrawingTable.SetColumnSize(4, 38)
Call oDrawingTable.SetColumnSize(5, 57)
Call oDrawingTable.SetRowSize(oDrawingTable.NumberOfRows, 10)
'Use the list created earlier in order to populate the information
'about Each part in the product structure.
For n = 1 To (oDrawingTable.NumberOfRows - 1)
Call oDrawingTable.SetCellString(n, 1, n + 0)
Call Dressup_Table(oDrawingTable, n, 1, 1, 0)
Call oDrawingTable.SetCellString(n, 2, QtyDict.Item(ProductList(n + 0).PartNumber))
Call Dressup_Table(oDrawingTable, n, 2, 1, 0)
Call oDrawingTable.SetCellString(n, 3, ProductList(n + 0).Revision)
Call Dressup_Table(oDrawingTable, n, 3, 1, 0)
Call oDrawingTable.SetCellString(n, 4, ProductList(n + 0).PartNumber)
Call Dressup_Table(oDrawingTable, n, 4, 1, 0)
Call oDrawingTable.SetCellString(n, 5, " " + ProductList(n + 0).Definition)
Call Dressup_Table(oDrawingTable, n, 5, 2, 0)
Next n
'SubError:
'MsgBox "Failed ", vbCritical, "Stack-Up"
End Sub
Sub Dressup_Table(current_table As DrawingTable, ByVal line_number As Integer, ByVal column_number As Integer, ByVal type_justification As Integer, ByVal bold As Integer)
' sort out the justification
If type_justification = 1 Then
current_table.SetCellAlignment line_number, column_number, CatTableMiddleCenter
ElseIf type_justification = 2 Then
current_table.SetCellAlignment line_number, column_number, CatTableMiddleLeft
End If
' get the current text
Dim current_text As DrawingText
Set current_text = current_table.GetCellObject(line_number, column_number)
' Set up the current text
Dim oText As Integer
oText = Len(current_text.Text)
' Font Arial
current_text.SetFontName 1, oText, "Monospac821 BT"
' font height
current_text.SetFontSize 1, oText, 3.5
' graphical attributes
current_text.SetParameterOnSubString catBold, 1, oText, bold
current_text.SetParameterOnSubString catUnderline, 1, oText, 0
current_text.SetParameterOnSubString catItalic, 1, oText, 0
current_text.SetParameterOnSubString catOverline, 1, oText, 0
End Sub
' Table dress up For bottom of tabulation
Sub Dressup_Table_bot(current_table As DrawingTable, ByVal line_number As Integer, ByVal column_number As Integer, ByVal type_justification As Integer, ByVal bold As Integer)
End If
' Font Arial
' font height
current_text.SetFontSize 1, oText, 2.5
Dim MyColor As Long
'Encoded RGBA color within long integer (R=255 G=0 B=0 A=255)
MyColor = -16000000
'current_text.SetParameterOnSubString catBold, 0, 0, 1
current_text.SetParameterOnSubString catColor, 1, oText, MyColor
End Sub
Jiří Pešek
[#225] | Publikováno: 02.03. 2010 - 22:29
Ahoj
nevim jestli ti to pomůže:
Dá se změnit barva celé tabulky a potom barva všech fontů.
Sub CATMain()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "Name='Title Block',all"
Set visPropertySet1 = Selection1.VisProperties
visPropertySet1.SetRealColor 255, 0, 0, 0
End Sub
[#227] | Publikováno: 02.03. 2010 - 23:30
Jirka mě předběhl, ale v podstatě jsem chtěl poradit to samé. Vybrat konkrétní tabulku pomocí Selection a pak jí změnit barvu pomocí visProperties. Tento postup funguje prakticky u všech elementů, které mají grafické vlastnosti.
Argumenty metody SetRealColor jsou složky barev RGB modelu (+ inheritance, implicitně 0).
Vaclav
[#325] | Publikováno: 24.03. 2010 - 10:18
ještě k selekci tabulky výše:
Nemůžu přijít na to jak vyselektovat tabulku se jménem kterou jsem vytvořil makrem o pár kroků předtím. Tak např. v řádku: *selection1.Search "Name='Title Block',all"*
bych místo 'Title Block' dal proměnou ve které je načten název tabulky. Bohužel tento způsob mi nefunguje.
Existuje ještě jiný způsob? Díky
[#860] | Publikováno: 16.07. 2010 - 21:41
Asi už to není aktuální, ale aby fungovala selekce přes název, musíte element najprve pojmenovat, takže zkuste třeba
vase_tabulka.Name = "My Table"
a potom
selection1.Search "Name='My Table', all"
mělo by to fungovat
